Hi
I have a 99 Disco that has ACE which a small leak from a hose that is attached to power sterring/ace housing. I had read somewhere theat these hoses, are pretty much metal based and would not be changed since it could alter the ACE charateristics. The hose I am looking at seems like an aftermarket rubber hose. My question is there any schematics out there that identifies the ACE configuration so I can get a sense on what it should look like? Its a small annoying leak that I want fixed since I have been feeding new fluid every several days. Its also not a hose that fell under the recall unfortunately.
Second questios is the bleeding of the brakes. I an considering doing this although my question is how do you know it will help? It seems the only solution is to upgrage the calipers but that's pretty pricey.
Thanks for any help particularly on the ACE schematic!
Charlie L
Charlie L
