Adding wood interior trim on 2006 HSE - my experience with an aftermarket kit
Jpyles
I thought I'd share my experience with adding woodgrain interior trim on my 2006 HSE. Mine had the factory woodgrain kit installed, which is a 5-piece kit that uses a laminate woodgrain with a matte clearcoat. Over time, the clearcoat can turn cloudy, as you can see in the attached pics.
I decided to replace the trim, but the factory trim pieces are extremely expensive ($1-2K) assuming you can find one. Plus, I was worried the same clearcoat issue could occur again. After some searching of aftermarket kits, I found a 3D molded kit online which included the center stack and both vents. This seemed like the best choice for me. I ordered the 3D kit from Sherwood Innovations in majestic burl.
Installation first involved removing the existing 3 trim pieces from the interior, which involves no screws or retainers - just pull straight out while holding near the bottom of the trim piece. The factory wood laminate was adhered to the trim with a type of rubber cement. The laminate could be carefully pried away from the underlying trim piece as long as you worked carefully from one edge. After removal, the rubber cement residue had to be cleaned off with a putty knife and some goo-gone. Of course, if you don't have a woodgrain kit installed, then you won't need this step. Just clean the trim pieces thoroughly to remove stains, dirt or oils from the surface.
Once the trim was cleaned and dry, the new woodgrain could be attached using the 3M tape that was attached to the back. The original factory laminate was a couple of mm's thick, whereas this aftermarket woodgrain was a lot thinner, about the thickness of a playing card. However, it was exactly molded to the contours of the LR3's trim pieces and the fit was great.
Overall I am very happy with the new look. It's a glossy finish, which is taking a little getting used to, since the previous wood was a matte finish, but it is MUCH better then the faded factory pieces!
Here are the original factory pieces, which had faded after 10+ years:
  • 69745d1466909929-adding-3d-woodgrain-interior-trim-image_1466909912558.jpg
  • 69761d1466911652-adding-3d-woodgrain-interior-trim-image_1466911636372.jpg
Jpyles
Here is the new woodgrain kit installed:
  • 69753d1466910393-adding-3d-woodgrain-interior-trim-image_1466910377296.jpg
  • 69769d1466911716-adding-3d-woodgrain-interior-trim-image_1466911701040.jpg
  • 69785d1466911858-adding-3d-woodgrain-interior-trim-image_1466911842531.jpg
  • 69793d1466911892-adding-3d-woodgrain-interior-trim-image_1466911874491.jpg
cmotomn
Looks great! Where did you buy the Sherwood kit and how much did you pay?
Jpyles
The kit can be found thru parts vendors like autoanything and carid. Initially I placed my order through one of those because I had a promo code, but my order was delayed several times, so I eventually cancelled it. I then called sherwood innovations directly and spoke to the customer rep and told him what I wanted, and placed my order. It took them 3-4 weeks to make and ship. The cost was around $140-160 US, I think, but I don't remember the exact amount.
I found a higher-res picture of a new side vent vs. old side vent, here goes:
whydahdvr
Looks great. I'm wondering what can be done to refinish the wood trim if it's not too bad. I tend to think some buffing or light sanding with a very fine grit and then careful application of sealant like polyurethane would work. But I can see that if it's too far gone, replacing is a cleaner and easier option. Makes me wonder what I should use on the wood trim I have to help restore it now!
toddjb122
Thanks for the write-up and nice refresh on your interior!
I'm sure people get in it now and can't believe it's a 10 year old truck.
Jpyles
I considered trying to buff/sand it, but you'd have to be exact enough to remove all/most of the clearcoat without scratching into the wood itself. For me, that was too daunting!
  • joey
