Air suspension faulty
Chamvari
I have a LR3 2007 HSE with a suspension faulty, I changed the pump with a new one but it's still coming with a red light on the dash board, the ECU is reading exhaust valve faulty on the pump wether I put a new pump or the old one, I also changed the relay.
What could be the problem, the Land Rover dealer has failed to fix it. :confused:
waspjr123
Did you try and see if the exhaust was plugged up ?
Chamvari
No i did not how do i check that? I was reading about the brake light switch where is it located.
waspjr123
The switch is on the brake pedal. And just follow the outlet of the pump it goes to the rear of the vehicle i beleive
Chamvari
Found the problem, cable behind the washer tank was making a shot with the body, i think when they removed the body the wires were not routed properly.
Thanks for the help
