L
LRMEX
Hi
I have a 1999 P38 Range Rover and this is what happen...
I was getting back from work today and notice a bit of oil under my LR on the usual spot where I park it. I got my self into work clothes and got to check it. Everything good so far. As I was getting don with my inspection I remembered I wanted to add a bit of grease to the bonnet locks. So I did that. In the process I pulled a bit to strong and broke part of the bonnet liver. I made sure it still worked and stopped tampering with it. When I started the car again the SRS Airbag fault was on the dashboard. I tried checking the fuses and they are ok. Can some one help, It scares me to have that kind of warning light on.
Thanks
Thanks
