Antilock brake light on as well as brakes sound like they are in bad shape
98GRDisco
Hello all,
First things first my antilock brake light is on is it more common for it to be the ABS Module or the sensors it came on at about 80k it has 92k now.
Second thing I replaced my brake pads all the way around about a year ago and this past weekend I replaced my rotors and pads in the front and now when I brake it sounds like the rotors I put on weren't smooth enough and my brake pads are being eaten up. Do you know if the ABS Module as anything to do with this because I read the brake system of the LR is unique.
Any help would be greatly appreciated.
Sounds to me like a stuck caliper, but you may want to check the rear brakes, since they normally wear faster on a Rover then the fronts.
As far as ABS, on a D1 it is normally a dirty or bad sensor.
BCNJ
