Anyone tried mounting 255/50-19 on HSE wheels?
B
BerryS
I've noticed at Tirerack.com that there are *many* more choices available in this tire size. Indeed, this is the OE spec for the closely-related Range Rover Sport. I'm wondering whether this size is mountable on the LR3 HSE without causing any sensor interference.
On a related note, are any Range Rover Sport wheels mountable onto the LR3? I'm looking for a 2nd set for winter.
Thanks in advance!
X
xcursion
Since the height ration of the tire is different (original being 55 series), unless you change the size of the wheel, there should be a slight diffence in your speedometer, odometer, and trip computer. You can ask if your dealer can dial in the adjustments (but I doubted).
