ATF change. ***?
Deadhead86
Ok, so this is the first time Ive change the tranny fluid since I had the new(used) one put in. I drained it and only about a gallon (4 quarts) came out. This surprised me! Now what surprised me even more then that, was when I went to put the new ATF in. I was working on putting in the second jug (4 quarts) when about 1/4 the way down it started over flowing! WFT? The Disco I takes about 10 quarts does it not? Someone let me know where I dropped the ball please!
Thanks,
-Josh
97' Disco I SE
T Disco
I just did this service myself, with new filter and added about the same tranny fluid. I think around 5 to 6 quarts. There is a cooler up front and associated pipes which probably hold the rest of the fluid. This would account for the more frequent tranny oil changes this car needs vs. similar newer vehicle. The manual states from dry, with no listing for refill.
When you drain the pan you will only get around 4 quarts or so... most of the fluid is in the torque converter..
Deadhead86
Ok, that makes sense now. How can I go about replacing all of ATF?
Thanks
Either several changes/run times, or go pay someone to do the work via a pump system that will change all the fluid at once via a pump.
Rendak
