I'm thinking about beach trips this summer and curious about driving on the beach. Have seen some awesome pics on some threads of folks driving on hard packed sand but want to know about soft sand...
I have 20" wheels with the stock Pirelli scorpions. The wheels are low profile... so lowing air pressure is limited... i'm very concerned i'll literally sink in the sand...
Should I be considering a set of 18" wheels/tires for going out into the Outer Banks (NC)? I'd like to be able to go where I went with my 4Runner - and enjoy camping out on remote stretches of beach...
Appreciate your thoughts.
1st, where are sand campsites you can drive to in OBX? Would love to do that!
2nd, I do this all the time in OBX. I have an LR3 though with the 19" wheels and even with those I always felt much more limited than the guys with 18" wheels who have dozens of more tires to choose from and nice big fat sidewalls.
Anyway, definitely air down. I am not familiar with your 20" wheels but on my 19" my mechanic told me LR made the wheels so it is VERY difficult to pop a bead with low air pressure (which was always my fear). He said it is actually a pain to change tires on the rims because of the shape. That's good for us. It is certainly still a concern but don't feel like you have to tip-toe around. Good point someone mentioned, though, about the low profile sidewalls not flexing as much...
Anyway, with sand mode and low tire pressure I have only gotten stuck a few times after a lot of driving. Only had to get pulled out once. The other 2-3 times I simply found that the tire pressure was not as low as I thought...getting it down to high teens is perfect. (buy a digital airpressure gauge) Put in 4 low. As long as you didn't bury yourself up to the frame you'll probably be able to drive out.
Pack a tow strap AND the hardware to connect it to your LR4. Depending on your strap you may need some u-bolts or something.
Finally, just accept the fact that it will not drive as effortlessly on soft sand as that old 4runner. Those mid-size SUVs are great. Nice big tires, light, and you can jump out on the beach without even lowering tire pressure. Not so with the LR3/4 no matter what Land Rover says. So....ummm, always stop near the high tide line. Just in case you are there for a while.
3rd, if you are going in the Hatteras area you will find the 4x4 driving area to be significantly reduced and much more of a PITA than it used to be.
