blue infotainment circuit 56 splice location
Ryan C
Massachusetts
Hello - Im looking to learn the specific (exact) location of the splice that connects the multi-media, satellite, and phone circuit. It’s the blue wire from circuit/fuse 56. It’s listed as splice SJ530 in the wiring diagram... p146
http://rave.stringsandints.com/LRL183853501(LR3-Wiring).pdf
I have most of the interior removed and have been tracing back but must be getting ‘lost’ in the 100s of wires.
Fairly certain this splice is bad as these components are not working and are not getting power... fuse is good and has power.
Thanks.
Ryan C
Massachusetts
Update - found it - if you are ever looking for the splice location that feeds ign power (BLUE wire) to Satellite, Phone, TV, and Multi-Media module ... it is located in the right rear passenger footwell harness; right when the harness turns to go up, and back, along the inner wheel well. I found the splice pulled apart with minimal force and was completely corroded.
Sid1577
