Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Ok, I finally replaced the master cylinder, flushed and bleed the brakes. Now I can get the peddle up by pumping it, but it does not seem to last. Any ideas?
Sounds like something is leaking somewhere... I know on my 97 I had a bad brake line that way leaking... changed the brake line and all was well again.
Check the master cylinder and see if one side or the other is loosing brake fluid.
Thanks Joey! Here is the other thing...when bleeding the brakes I was not able to get the projectile stream from the front as I did with the rear. The front was kinda like oozing, but was able to get the air out. So I assume the problem may be with the front??
brake fluid is a superb moisture magnet! The trouble with standing vehicles over time - without bleeding the braking system out is, believe it or not, moisture seems to find its way in (or most likely via the moisture in fluid itself as it ages/breaksdown)
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
