Change LR4 default vehicle height
pceresia
Ottawa, Ontario, Canada
Can anyone in the LR Community advise if the shut off default vehicle height can be changed. Specifically I would like to see the vehicle go to its lowest height on shut down and raise up to normal preferrably on movement but on startup would be acceptable. I would like this to happen as a matter of routine not as a manual input. Is this something that could be programed?
Thanks
remember5
Well that seems to be a common question and evidently there is no way to automatically drop to access mode based on what I can find in the manual and on line. Most users hit the lower button right before they get to their driveways and it's down when they get stopped.
pceresia
Thanks for your input. That is the best approach I've been able to come up with as well. Its to bad the automakers don't extend their customers the same flexibility that computer app designers do.
Keanan
This could be a nice feature.
A real OCD owner might not like this. Articulating the lower bushings every time you park could cause premature failure. A guy wouldn't get any sleep a tnight knowing those bushings are under unnecessary tension. haha
