Charcoal Canister or Purge Valve disconnected
hi_arshard
Hi Guy,
In my 95 disco1 the tube from the Purge valve is disconnected.
There are 2 tube connected to the Charcoal canister the bottom one is running right back to the of the truck I guess that is heading to the fuel tank other from the purge valve is just hanging out with a T joint not connected anywhere.
I have no idea where these 2 tube should be connected Please advice where should i connect these 2 ?
It would be much more appreciated if you could provide a diagram or a picture.
& the fuel consumption is very bad around 180 to 190 KM per full tank, & there is no black smoke as well. is this something to do with the above disconnected purge valve ????? please advice appreciated ur support.
If you have the Rave, open the D1 section and go to page 190, if you do not have it, download it.
Sid1577
