compressor air assembly question
J
jwordie
Hello,
I turned off my 2001 DII today and to my surprise my compressor for my suspension kept running (loudly too) and won't stop. I don't see any sag in my suspension and I need to drive my truck - but I don't want the compressor to run on so long it kills my battery. Dumb question I think, but can I disconnect the compressor and drive it? I think that the answer to my own question is no, as it probably needs to make constant minor corrections to the suspension throughout the trip - but I thought I'd ask anyway.
Thanks for your help.
JW
T
thetasig28
Had the same problem on my 99DII about 4 months ago, there was a cracked plastic elbow that comes out of the top of the compressor. LR could not supply the part and suggested i replace the whole compressor, did the coil conversion instead. check the system for leaks, thats what will cause it to run constantly, and eventually burn up the compressor. good luck.
tragic1
