Condensation in Front Headlamp Assy
W
wmg1971
Hi all!!
Just wanted to know how to remedy condensation in my passenger side headlamp assembly...It happens every winter here in Vegas, and I wanted to know if I have to purchase a new Lamp assembly, or if there's something I can do to fix the problem...Thanks!!!
96Discose7
remove the lamp from the truck and dry it out , run a seam sealer all around the lamp at the factory joints, then you need to see if your bulb seals are torn or broken, also look for any stone chips in the lens itself, water will work it way in there too -Andy
I bet winter in Vegas is a ***** to deal with
W
wmg1971
Andy, thanks for the reply...Now, where can I get seam sealer? Is it available in auto stores? I think the bulb is ok, because when I first bought the truck 2 yrs ago used (2000 Disco), it had condensation in the lamp assy already...
Warren
W
wmg1971
Oh, forgot to mention that I had already switched out the old bulbs with new ones, after I bought the truck and noticed the condensation in the lamp. So, I'm guessing the bulb is fine...It dries up when it gets warmer, and starts "sweating" again in the winter...
Warren
96Discose7
you can get what you need at any auto part store, either a] glass stone chip sealer(to fix chips in the windscreen) or b] just a tube of permatex brand .....damn i cant think of the word...... oh this is going to drive me nuts.....
ummmmmmm........ errrrrrrr...... just look in the adhesive aisle but its not really an adhesive, it clear...its.....its.... i give up anyone else???? help a poor guy out........
96Discose7
Duh
Silicone will do the trick, or you can use a Hylomar gasket sealer which is made by Permatex now I belive but its the same stuff , good luck and don't forget to check the rubber boot around the bulb and the o-ring for the city/sidelight -Andy
Paul p
