Coolant fluid leak under the engine
tharun_d
Hi all,
I have a coolant fluid leak in my 2003 Discovery SE. I went under the truck and I found that it is falling on the cross member on to front propeller shaft. I am not able to figure out from where it is coming from. Also I have oil around the head of the engine..it looks like head gasket gone bad. Any suggestions are really appreciated.
Can some one please suggest a good mechanic in Cincinnati, OH to whom I can take my vehicle to?
Thank You.
Nippythegreat51
First time in
Hello to the Landrover community....
Got a 2003 Discovery SE and wanted to respond to posting regarding the water leaks.. Since owning our vehicle out of warranty, we have responded to water leaks two different occassions.. First, we had the intake manifold gasket replaced, but also took care of water pump and gasket during same repair. So, if your manifold gasket is leaking, you might want to consider new pump and gasket based on future $ dollar repairs; our mechanic is good and thorough... Secondly, there is an assembly on intake area which also can leak ... can't remember off hand, but we also had that gasket replaced...My mechanic has an older Discovery and told me up front, complaints were water leaks,
Good luck
PanKyiv
