When checking the coolant level in my 2015 LR4 SV6, I noticed what appeared to be oil in the coolant reservoir tank. I had the vehicle transported to a workshop to check where the oil could be coming from, thinking oil cooler most likely (as it had recently been changed). The car has a history of losing coolant and the cooling system has been pretty much replaced piece by piece.
The workshop has advised that the transmission needs to be rebuilt as it’s full of water! Is this possible? They’re saying the transmission cooler or a seal to it has failed? They haven’t explained where the oil came from. I haven’t yet seen an itemized quote but would a rebuild be necessary or simply flush, replace seal and move on? Any advice gratefully received.
