96Discose7
has anyone had a leak at what i belive to be the transmission cooler line that is just below the upper radiator hose [steel ridgid line] there is a little coolant that ****** out at startup but i dont see dripping after i stop later on... just at start up and idle in the drive for a few minutes..... can i drain some coolant and clean the threads and put some plumbers tape on and tighten back down????
this will be my saturday project as it will be a balmy 20+ degrees -Andy
