Coolant pump hose repair
russburcham
Good Morning guys,
Was wondering if anyone had any advice on installing a new coolant hose --thermostat to water pump- the one that also goes to the resevoir...found a pin hole in mine last night. I was looking around and saw that the bottom connector may be a tight fit...
Thanks as always and hope everyone is having a great holiday season!
Russ
The coolant bottle can carefully be picked up from out of its clamps, just be careful to not break one of the plastic pipes.
Make sure you bleed the system properly when done.
PanKyiv
