Coolant warning Light?
T
TCDown
I have a 93 Classic 4.2 LSE the coolant warning light started flashing on my way home last night. I have checked the water level when cold and topped up appropriately but the light won’t stop flashing.
Any ideas?
Sensor going bad.
I would also check the to make sure you not getting too hot. use a temp gun to read the radiator temp in several different areas.
I still say a sensor, but it doesn't hurt to make sure.
T
TCDown
Turns out it was only the slidy bit on the level sensor that dips into the expansion tank was limescaled up. Bit of elbow grease and i am back in business.
Glad to hear it was an easy fix.
Slytrellis
