dead battery reason for fault
97rover
The battery in my Range Rover is toast that is why it is throwing the fault. Does anyone know if the battery in my 1997 Disco will fit in my Range Rover. Both have the 4.0
It should be the same battery.
97rover
Cheaper to buy disco battery
Found out that the battery for Disco is only smaller in size so that it can fit in battery housing. Cold cranking amps are more in the Disco than that of the Range but will still do the job. Just made a bracket for the Range Rover. The battery for the Diso is about $30.00 cheaper here. Checked 4 different locations all about the same.
helge
