Disco 4 steering issues - this one is strange
Gunnar Halldors
Iceland
My 2013 LR disco 4 has a strange steering issue. When cold in the morning it's like new. But when the engine heats up the steering becomes heavy and I need to give it gas so I can turn the wheel....
No sound when it is cold and very smooth. After 10 minutes there is a slight dimm squealing sound when turning, but disappears when rpm goes over 2000
Could it be: The power steering pulley is misaligned??
PaulLR3
Boston
Are you low on power steering fluid? Could be a leak somewhere.
Mine was the opposite, my steering felt sloppy and it turned out the steering rack was leaking fluid. With a new steering rack it now feels like it corners on rails. (Compared to how it felt before the repair)
scott schmerge
Charlotte, NC
could be a coolant leak causing belt to slip. I’d check water pump for failure
mklinker
boston, ma
Did you have a remanufactured steering rack installed, or a new unit?
