DiscoI won't leave park
clockmaker21
Disco II 2001 can start but will not go out of park??? anybody help? everything else works??
toecutter
brake light switch
it could be a simple as the brake light switch,check and see if your brake lights work.if they still work check the fuse box under the steering wheel for a bad fuse .if thats not it ,you will have to wait on someone that knows moer than me.my d1 did this often when i wired up my trailer lights,i didn't use a converter box and they blowed my brake lights out.then the park interlock would not release,just as if i didn;t put my foot on the brake lever.hope this helps.
clockmaker21
Disco park prob.
I pulled the fuseses and checked all...hard to tell which fuse is associated! all were fine. tryed the car again and all worked? The brake lights always worked? maybe I should replace the brake light switch just in case. Patrick
Brake switch or the third brake light might be corroded, the D2 if the third brake light doesn't work you get the same issue.
clockmaker21
trans fluid
Seems like a dumb question ...but how do I check the trans fluid..can not find a normal "dip-stick" and nothing in the owners manual. Thanks for all the help, Patrick
Dubbs
To check the trans fluid, you will probably have to get under the vehicle. If you don't have a dip stick, there should be a bolt on the upper part of your tranny. You unscrew the nut and, a: try to feel for oil, or b: just pump some more fluid into it until it leaks out. Then put the bolt back in.
I have not done it on a LR, but my toyota is that way. I'm thinking those are your only options. Good luck.
clockmaker21
trans fluid Disco
Really that is how technical the operation is? There must be a more axact way???? Patrick
