DiscoI won't leave park
toecutter
i had a d2 the dealer told me to start the truck run it through the gears.then shut it off,take the plug out and add trans fluid till it over flowed.they said to check it before the fluid gets hot.add the fluid then start it again run through the gears,shut it off take plug out and see if its still up to the plug hole.if it is your good to go.
Dubbs
I think they do it that way so you just bring it to the dealer and pay an insane fee. Common sense would be to put in a dipstick, but that doesn't bring the dealerships money. If you want to do it yourself, you'll have to get a little dirty. Sorry it's so indirect.
clockmaker21
trans check
Thanks...not afraid to get dirty! Just seems so so sophomoric(sp) Again I thank all for help. Patrick
Not a matter of getting dirty, it is more a matter of burning your arms on the exhaust.
Dubbs
I wasn't trying to offend you. I was just taking a stab at the dealers. I'm not implying you mind getting a little dirty. My apologies for the insincere insinuation. Good luck with you Land Rover.
molson
I had a similar issue w/ my Disco II about 2 months after I had purchased it back in 06. I sat on the phone with the local dealer and they walked me through how to install the new Brake Switch module under the driver's side dash. I had to remove one plastic panel with a few screws to get to it, but it was a fairly simple switch. When I got to the shop to buy the switch, one of the guys told me to keep a spare one around just in-case. You're a sitting duck if yours goes out. I've had a back-up for the last 2 years and haven't had the need for it yet, but it's there...I panicked at first, i thought that I had blown my tranny or something major went wrong, but it turned out to be a $35 part and free install by me. Hopefully this helps albeit a little late...
