Z
z00100
Greetings,
This is my first post here, so please go easy on me.
I have a 2004 LR Discovery 7 Seater. Ever since i've owned the car, I haven't really had any major problems, but I've had "issues". Some of the issues I can deal with, some, I don't know.
For example, since about 1 year now, I can "hear" some sort of vibration in the car once the car is idling at a red light and the AC is turned on. If I turn off the AC then it goes away. I have figured out that this vibration is caused by the engine idling a bit higher and under load once the AC is on. The vibration sounds like 2 thick metal or plastic plates resonating against each other with the frequency of vibration of the engine. If I rev higher it goes away, only under idling does it appear.
Secondly I am facing some squeaking sounds from my front and rear suspension. Example: When I start the car in the morning (15C ambient temp), and drive away, I have to go over a speed **** near my house. If I drive fast enough so that the suspension has to compress and decompress a lot, I hear a grating sound. Sort of like as if 2 joints are not greased properly. This only happens in colder weather and dissapears if the suspension gets "warmed up" by driving a lot.
Thirdly, and this seems to be a major problem, is that my transmission jerks from first to second gear (I have an auto tranny). Shifts from 2 to 3 and 3 to 4 are smooth, but 1 to 2 jerks. I thought this could be because of a cold transmission, but it happens most when the transmission is cold, but happens also intermittently after driving for a while.
I hope you guys can help me out, because I really like my Disco and want to keep it.
Also just out of curiosity is getting 380-420 per full tank normal for my Disco?
And another thing. I had to change my battery and the Radio is locked out and asking for a code. I tried putting in the code that came with the small tab with my Keys, but it doesn't work. I have already inputted it 7 times (wrongly) and I have read that the 12th time is the last time and that not even the manufacturer can "restore" it back to working condition.
Regards,
Regards,
