T
tcosson
I just replace the lower intake gasket on my 99 Disco along with O/2 and MAF sensors. I can't for the life of me find any OTA coolant around here. Will the coolant that my GMC uses work in the Rover with no problem's or does the OTA type really matter.
Also I cracked the plastic line that goes from the coolant resevoir to the intake heater. Will I be fairly safe clamping a hose over that untill the new piece comes in or is it going to have enough presure to cause a leak?
Wish me luck tommorrow I should be cranking it back up....
