Engine stall, reduced engine performance
....nice to hear that the 5.0 can do that kind of mileage!
stl8grey
Yes. I honestly I believe it would go longer on the highway had it had a regular coolant system. The heater manifold pipe on the back of the block began to leak at the seam. Then that small dinky curved water pump hose with the small quick release began to leak at the quick release inlet and well, from there it just gets worse. Naturally all those items along with the radiator are new. On the farm we run it all day because it blows collllllld A/C. You can even nap in the back cargo area if you lay all the 2nd row down.
"crossover pipe" from the water pump is a common issue as is the timing chain guides/tensioner.
Yeah very comfy in the LR3/4. I've folded the 2nd row flat and slept back there many times!
