62Sunbeam
So now when I'm driving up a grade of any significance my Disco will miss and then the Check Engine Light comes on. From that point on it runs sluggishly. I've been thinking all along that I have a fuel delivery problem but yesterday I got motivated and looked at the code reader and it says 02. From what I've read this usually means a fault within the ECU.
What I'd like to know is that the only possibility or might it be a bad connection or something and if in fact I need to replace the ECU does anyone know where I can get a replacement?
New? Used?
Should I just set the Disco on fire in a crappy neighborhood?
Again, any and all info is appreciated.
Thanks
Eric
'95 Disco 169K miles
New? Used?
Thanks
Eric
