Error Codes P0171, P0174, P0734
dfayette
I'm looking for the most likely solution to P0171 and P0174 error codes. Most likely the air pump but how can I prove it?
The error reads lean on bank one, and lean on bank two. I'm guessing the pump has gone bad but not sure how I can know for sure.
Also I've been getting random P0734 codes, which show wrong gear ratio in gear 4. I clear it and it comes back days or weeks later. I suspect something with the rear axle but not sure where to start looking.
Disco Mike
Those codes are an indicator of a failed MAF. How often do you change your air filter, are you using a paper of a K&N type air filter? If K&N, get rid of it.
dfayette
I don't use K&N on the Range Rover but change the filter every 5K miles since we live in a dusty environment.
Can a dirty filter cause these codes or do I need to replace the MAF?
Disco Mike
Yes it can.
If you have any questions, send me your tele number and I'll call you.
dfayette
Error Codes P0171, P0174 and P0734
My phone number is 425-301-6487
Is there a test for the MAF? I checked the filter and it's not very dirty. I'll replace it anyway. The MAF "looks" good but it would be nice to be able to test it prior to replacement.
Gold Yeller
Annoying MAF faults
Hi dfayette & Disco Mike: I was wondering how you were able to get your problems resolved. I'm having the same issue, somewhat. I own a '99 RR 4.6HSE, all stock except for the replacement K&N air filter. At first, I was getting error codes P0733 and P0734, erased the code. Then, I cleaned the MAF with the MAF spray cleaner. Drove and got 20 miles out before the light came on again, this time stating P0171 and P0174. I'm gonna clean the MAF sensor again, erase the code again. If it happens again, I'm gonna slap on a regular replacement air filter.
dfayette
I replaced the MAF sensor.
Cleaning did not work. K&N should be just fine since it does not interfere with the MAF.
Gold Yeller
Thanks, it looks like I'll go that route myself as I replaced with a WIX paper filter and still did not resolve issue.
Disco Mike
Replace the MAF, since cleaning won't help that particular one, use only factory air filters and throw that K&N as far away as possible.
RoverProblem
2001 range rover codes
Disco mike
I have a 2001 range rover I read your reply for this thread and bought a mas air flow sensor from napa its not a Bosch brand is that okay? With this sensor I get code p1775 p1772 p0447 please help any one I spent way to much already trying to fix this car
