Front AC not working
mrdonthate
2006 LR3
I bought my lr3 used over a year ago. About every 4 months I would get a burning smell and then the front AC would go out. I would change the Fusible Link and everything would go back to working.
This time something finally died because replacing the FL does not solve the problem. I have no AC no matter which speed setting its on
1. replaced fusible link - no luck
2. replaced blower motor - no luck
3. swapped relays under the hood - no luck
What next step should I try. Would changing the blower regulator be a solution
http://www.roverparts.com/Parts/PCE500010G.cfm
outdoorjunky
Hey bud where is the fusible link at my blower just quiet up front I checked all the regular fuses with no luck.
Thanks
tlt
Wow, you've been pretty thorough. It doesn't seem like there is much left. While we are waiting for other suggestions why don't you post a how to replace the items you've replaced?
Does the vehicle also have the rear AC unit?
Does it rain allot there?
Water in the cabin?
Shorts in wiring?
Johnathon65846
