Front and rear wipers
montreal
Hello
My passenger front wiper decided to stop. the driver wiper is still working. What is the probable cause and what should i check?
I changed the rear wiper blade and it still miss a lot of my rear window while wipping... do we have to change the spring?
Thanks very much
Luc Saint-Jean Lcol
Front wiper. Check to see if the spline hub is turning or not.If it is you may just have to tighten the wiper arm itself.
Back wiper: The arms do this as they corrode. Spray the articulation points on the arm liberally with WD40 and work the arm back and forth repeatedly. I do this every spring after a long hard winter. Like most rear wipers the design is not great and they lead a hard life.
PE_in_UAE
