Front Light Washer
M
MightyMax
My Front light washer jets aren't working. Where should i start looking first.
95d1
The jets only work if the lights are on and you have to hold the lever for a minute. If you have done this check the pump in the back(firewall side) of the washer fluid tank. Get someone to pull on the lever and see if *** is pumping. It maybe that it just was disconnected as mine was. Good luck
MrRodgers
