Fuel Filler Latch Assembly Help (time sensitive)
KCMaverick
Hey guys, need some help repairing the fuel filler latch assembly (the section of the assembly on the vehicle, NOT the fuel filler door). I cannot see how to get the fuel door actuator (part ARV780020G) and the Fuel Door Spring Retainer (part BPA780110G) off to replace them. I have the latch repair kit with all the plastic parts and the spring and access to the shop manuals, but I can't seem to figure out if I need to take off the body trim to gain access, if the black trim immediately around the inside of the fuel filler area pops off, or if I need to just pull the parts out by force where they are at. Please help me understand what I need to do to fix this. I'm also in a hurry because I'm going out of town for work and won't be able to do this for a while. Pictures, video, and/or felt board explanations are always welcome, but anything will help and is GREATLY appreciated. Thank you!
tlt
The parts should just pull out. Then the fit back together in a certain order, and orientation.
Here is a thread, and a couple of pictures which should help you. Substitute . for / and remove the spaces.
disco3/ co / uk/ forum/topic75027.html
KCMaverick
Thank you! Everything was easy and the fuel filler door is working great. If anyone runs into the same problem, the link about is great. Thanks again.
