Fuel pump relays
D
discoskc
Could anyone tell me where the fuel pump relays are located on a 95 Disco?
SKC
95 Disco
68K miles
L
Lendawg
It's funny you should ask.
I recently changed my fuel injectors. In the shop manual, it says to pull the fuel pump relay and run the engine until it dies in order to deplete the fuel rail pressure. Well, try as I might, I could not locate the relay described in the manual. They say it's in the right outer kick panel area, under the ECU. They even had a picture that did not match what I saw in my '96 Disco. What I wound up doing was pulling the fuel pump fuse near the battery. It did the trick.
STQAddie91
