Gas Tank Recall
W
w6000
I have been to my dealer four times since October to request the replacement of the gas tank. Each time they have told me that they have no replacement tanks. So I asked them if they have done any of the replacements. They said that they have not done one of the replacements. I found this very hard to believe. Would somethin like this be covered under the Lemon Laws, since they have not fixed the problem.
L
LR3Dude
I live in Northern Virginia and my LR3 HSE tank was replaced 1/19. I "only" had to wait two weeks for an appointment. Offered a Enterprise rental car but I skipped it since it's usually some compact car. I did get a full tank of gas but no other freebies. Folks on the forums indicate dealers can offer some freebies up to $100. Since it's NHSTA recall, I don't think lemon laws apply (laws vary by state), unless they keep replacing your gas tank :) I would follow the guidance in the recall letter regarding how much fuel to put in the potentially defective tank since it's a safety issue.
L
lr3socal
Same here, I waited about 2 weeks for the gas tank, but no full tank of gas or a sorry for the problem. We got a loaner since it took 2 days to fix.
W
w6000
I guess my question is since this is a NHTSA recall, is there a time limit on how long Land Rover has to fix the problem?
JohnKel
Hi W600 I have a couple of questions
1 have you recived the recall notice yet.
2 have you had any of the symptoms ie: gas smell, check engine msg, hesitation.
3 Are you sure your vehicle falls into the recall range
Link for the recall...you can read all docs (pdf ) pertaining to it
http://www-odi.nhtsa.dot.gov/cars/problems/recalls/results.cfm
HTH
Cheers
John in NE Ohio
W
w6000
HTH
Cheers
John in NE Ohio
yes to all the questions. I got the recall notice four months ago.
PE_in_UAE
