GREETINGS
HAYWARD WATTS
WINCHESTER, VA
I have a 2004 Range Rover HSE with 112K miles just changed the plugs last nite and found oil in 7 of the 8 plug port...plugs were soaked with oil...truck is running fine...no smoke...I wanted to know if anyone else has experience with this and which gaskets are bad? thanks for any input with this problem!!!
Globetrotter
Australia
If the plugs ends where black, then you may have the wrong plugs or running to rich. If plugs where a grey/brown and the oil was only in the well, you may have a rocker cover gasket loose.
