Headache 03 Discovery
Roving72.
03 discovery is giving me trouble codes P1300 P0304 P0306 P1451 P0300 P0135 P0134. I have replaced both upstream O2 sensors both are bosh. I have replaced the maf sensor bosh. I have also replaced the cam sensor. I have also replaced the plugs and all the wires 8mm. I found the 15 amp fuse that governs the circuit blown this is located under the hood. I found the leads for sensor one bank 2 shorted out and burnt they were fixed replaced and have good connectivity. The only thins I have not replaced yet is the purge valve and both coil packs. The truck Runs at idle smooth but as soon as you put it under load it stumbles.
confirmer
Well as you mentioned the purge valve and both coil packs aren't yet replaced. Have it replaced and make sure all error codes are clear.
Nico3dd
