HELP - Driver Elec Door Lock - 97 Discovery SE7
DiscoWife
I am new to the forum. I need help desperately!!! My husbands 97 Discovery SE7 with 141,111 miles on it is having some issues. He is not mechanical at all. The drivers door lock won't unlock with the key or the fob. Key will not turn all the way, the sill button will move but won't release to let it pop up...
Am I am making sense? Anyhow in order to get it to the shop to get other stuff repaired, I have to get that door open and hopefully fixed.
Is it the ECU or the lock assembly in the door. Other locks seem to function fine. the open when you use the fob.
You most likely have a failing lock assembly or the linkage may have come apart.
The ECU is not the issue. Have you tried getting in from one of the other doors and pulling up on the lock button?
davidsussex
