So, I'm trying to remove my right-side, rear rotor from my LR3. But, unfortunately, I'm having no luck.
Once the wheel is removed, I then remove the caliper off of the brake disc. I've then removed the EPB tensioner plastic cover. From what I've read, I'm to then rotate the brake disc towards the front of the vehicle; this is to align the exposed hole (which I removed the cover from), with the EPB adjuster. Sadly, this is where I'm running into trouble. I can only rotate the disc forward about an inch, and then it won't budge a hair more. I've checked in the hole, and the tensioner is not visible in the 1-inch movement area at all.
My EPB is making a ton of noise, and I desperately need to swap out the shoes for new ones that I've picked up.
I took a short video to illustrate my problem. It's available for viewing at: http://youtu.be/4gug1VPLcSY
The weather outside today is unusually warm (52 degrees), and I desperately want to get this work done today. So, any insight would be greatly appreciated.
