hood release
K
kram2179
I've tried popping the hood on my 99 Disco II and it isn't releasing. Is there any other way I can get it to open other than the inside release?
You can try to pull the handle and have someone lightly tap the hood and hope in opens, or try to pull the cable with a pair of visegrips....
If those two do not work.... you will have to remove the grill and then take apart the hood assy. this is not fun.
M
Mark
If it is like the D1, have one person pull (gently) on the release latch and you lift the hood. When mine sticks, I just pull, walk around front and llift. No problem.
W
will
I remember having to pull really hard...really really hard. Either that, or all other cars have really light hood release latches..
D
disco1
I won't add similar suggestions as already posted. If these fail, arm yourself with a long screw driver. Look under the hood and you will see the latch and next to it the "striker pin". Have someone pull on the hood release handle inside you vehicle, while you (or better still a third party) gently push the hood up and down. while all this is going on, insert the screw driver under the hood and push against the striker pin form either side until it releases. Once you have the hood open, inspect the plate that the striker pin goes through, and initially spread some grease around it, or you might just undo the bolts holding the plate and slightly re-align it. As a tip in the event of future hood opening problems (when you don't have the extra hands available), such as solo off-roading, tie a thin piece of wire around the hood release catch.
Hope this helps.
D
DiscoInferno
and don't forget to grease that latch to kingdom come before you shut it again!
STQAddie91
