IID Tool - What are your favorite features?
Paxton407
I'm considering purchasing an IID Tool and I'm curious what everyone's favorite features/uses for it are? From researching the forums, I've found some of the common uses to be:
Suspension height adjustments
Enabling global window close from remote
Enabling chirp on lock from remote
Enabling digital speedo (older models)
Changes to parking sensors
Resetting of faults, service minders, etc.
What else do you guys use it for? Would love to see some lists of changes from experienced users.
Also curious if the tool is able to do any of the following -
Feature to disable eco stop/start?
Reprogram key fob remote buttons?
Ability to change behavior of fog lights and use in "Auto" headlight mode?
Auto access mode on park?
Disabling feature which stops height adjustments when doors are open?
Change behavior of one touch windows/sunroof?
AxelR
Disable TPMS. Don't we all check our tire pressure ;)
iSurfvilano
North Beach, FL
Did you ever make the purchase? Did it live up to your expectation?
What sort of values is everyone able to get with the "height" feature?
Mine is limiting me to raising it an additional 35mm. Is that a maximum across the board, or is that my personal maximum based on the pre-existing sensor calibration on my specific LR4?
The EAS values are unique to each vehicle, therefore the number of mm of additional lift allowed will vary quite a bit. 35-40 mm is probably about average. Very few are able to get 50+ mm adjustments, and some are limited to 25 mm or less, depending on their initial calibration numbers.
I don't use IIDTool to raise my suspensions (using Llams height module instead, which "blindly" allows +50 mm at its highest setting) but I was in your ballpark when I tried it.
Thanks. Just wanted to make sure I was in the same ballpark as most others. It appears that I am limited by my driver's side front.
backcountryLR4
Utah Backcountry
First time I plugged it in the tool said 35 was the max to stay even. Plugged it in later and it said 43mm was the highest.
I would say it is worth checking again.
