Installed Mud Flaps and Guess What
W
w6000
I installed mud flaps on my LR3 and I noticed that they seemed to not line up properly. The left one seemed to be at a different angle than the right one. I thought that maybe they were bent or something, or maybe I put them on wrong. So I took tham off and I noticed that it was not the mud flaps but the tire. It seemed slightly bowed out. I measured the rear of the LR3 and the right side is 3 Cm taller than the left side. I would never have noticed this if not for the mud flaps. They gave me a lateral line to see the difference in height.
Has anyone seen this? or can give me some insight? 3 CM seems like a big difference in the height of the car.
Moose
Old Discos were offset like that to allow for the driver's weight. Maybe they kept it up for the LR3?
T
texas911
Which is the left side? The Driver (US version) side? Might be something with the air suspension, because its auto leveling. It should be level to matter what.
D
disco1
Just trim the one that's too long.......(Jeez, this new tobacco is good s**t)
L
luvmylr3
Was the vehicle on level ground? It self levels, so if the ground was tilted left to right, then the there would be a differential in ride height left to right.
W
w6000
I have checked it at a number of different situations, always the same. the right side is higher than the left side.
Moose
We're talking a LHD model here right? Right side = passenger side; left side = driver's side? Or the opposite?
speedmancool
I had that problem when I bought my 2004 discovery. I took it to the dealer and the recalibrate my self leveling suspension, and that was it. The problem dissapeared. Hope this helps
landrover san j
Your Lr3 May Have A Leaking Airbag On That Side Or Needs To Be Calibrated At The Dealer. If You Let Your Car Seat For A Few Days Does It Drop More On That Side?
Hae79547
