INSTALLING Fuel Door Hatch CLIP LR DISC 2003
Eastali
I have been through 2 fuel door clips, I cannot figure out how to install it.
If anyone knows please help!!!
This is the black plastic clip that connects the fuel door to close.
I have a 2003 LRover Discovery SE
Thank you!!!!
Alicia :stupid:
98Disco
Well just pop the old one off with a small flat screwdriver, the new ones can be a bit tricky to install without breaking them. They have 2 things to look at one is a round pin the other is a 1/2 inch long plastic arm. What I do is slip the arm into the slot with the round pin at the at the top then rotate gently clockwise until the pin lines up with its hole, and snap it in. It is very easy to break off the plastic arm portion so be gentle, tho if it does break off it should still work fine as long as the pin portion snaps into place correctly
Eastali
Gas Door Clip
THANK YOU SOOOO MUCH!
I didnt think I was going to get any replies on such a silly question~
I have gone through 2 brand new ones and I am on my last clip now.
I love my truck but what a pain in the ass!!!!
You did your "good deed" for the month!
Alicia A. Harmon
SulliMtn
