lift choices
B
basstard440
I read about some different ways to get it up but I still am not sure about the right choice. There are spring kits and there are spacers, What would be the better choice? 2000 disco with ace. They say this has a great suspension on it so why go with the spring kit? On the other hand I have a jeep with OME
suspension and I know that there is no comparison to simple bolt on crap to make it do what it does. In my Jeep after purchasing "THE COMPLEAT KIT" I spent much much more on things I needed, like a slip yolk eliminator, real shackles, drive shafts and shims, all this just so my drive shaft would not fall out! So if I lift it should I expect to have similar things that I must do? TY Joe
If you don't go more than 2 inches you will be fine... any higher and you may need to buy more parts.
BCNJ
