Lift Question
JLRPilot
New York
Question regarding a lift on my 2016 LR4.
Currently have 2-1/2" Rhino lift rods and the rear seems high.
Has anyone ever put a 1-1/2" in the back and 2-1/2" in the front.
I have a similar lift on my P/U truck and love it.
If so, how does it effect handling and if there IS someone out there with it can you post any pictures?
Thanks!
Jimmy Brooks
Pasadena California
Thanks!
When I got my wheels and tired originally I recalibrated the whole air suspension system and either put it half and inch or a full inch higher all the way around to make the ride height match the look of the bigger tires. I think it sits at a perfect height now, just a little higher than factory but not too high to mess with the way the truck drives.
Regardless of what you do, after any height adjustments you need to get the car aligned and make sure the suspension is in tight tolerance
JLRPilot
New York
I'm hoping it would self regulate to more of a proper balance.
I'll update and let you know.
Thanks
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
I'd check that you aren't out of spec. You should be able to measure from the center of the wheel to the wheel arch, and cross check to the workshop manual, accounting for your 2.5" lift. It could be your rear end was configured to be high, independently of the lift rods.
