Lifting an RR
2001RR
Anyone lift there RR using the airbags? If so how did you do it? Or if you know some where I could find out how to. Thanks
T
testuser
Conversioin to springs is a pretty safe bet. What year.... oh, 2001.
2001RR
I dont wanna lose the air bags. Anyone know if the bag mounts are welded or if they are bolted to the frame?
tmiller1
Lots of people have succesfully gone through the conversion...
That said, you may be able to install some different airbag height sensor arms, which would force the RR into "thinking" it needs to raise itself - effectively lifting itself. I know that DiscoMike has done this with his Discovery. He installed Old Man Emu springs in the front, and changed the airbag sensor in the rear to lift the rear to the same height as the new springs in front.
Personally, I would probably swap out the airbags for Old Man Emu springs all the way around (if your RR was mine). Just my opinion of course...
2001RR
Ging with springs is like down grading. With the bags you have more options when going off raoding than you do with springs.
Hae79547
