Loosing coolant but no puddles or smells or aything
98GRDisco
Ok here s the deal on my 98 Disco with 107K my heater cut in and out so I checked the coolant it was low like expected; but it has been a little over a month and the heater started acting up again so I checked the coolant again, it was empty. It being only a month since I filled it last I believe I have a coolant leak but no signs of puddling outside, floor board not wet from heater core, I was told it may have a leak into the block. I will be checking the spark plugs this weekend.
Question is:
How common is it for 98 Disco 1 to have cooling system problems?
Where else should I look for a leak?
Any help would be appreciated.
If it is a Rover the odds are good to have coolant leaks.
I check my fluid levels weekly at minimum. The odds are you either have a hose clamp seeping, or the rear of the intake manifold is leaking.
Could also be a head gasket. Check oil if you are increasing in oil... bad, if not it is just a leak and keep filling and drive.
As stated the cap could be the issue, and if you still have the old black tank, this could be leaking as well.
Mtn Busa
I didn't have this on my '96, but do on my '03. Usual failure mode is the valley gasket so the coolant doesn't make it to the ground.
Talk to a Land Rover tech who can explain it better than me.
Mine loses about 2 oz per 2000 miles so it isn't a big deal. I just check the fluid regularly and top up the reservoir.
wolf
Like Joey pointed out - don't forget to check clamps as well - you can lose quite a bit through a slightly loose clamped area when its under pressure (i.e., it will mist out so you won't get the tell-tale stench that you get from big puddling leaks). Of course, my main eak turned out to be the intake manifold/valley gasket at the rear (i.e., toward the firewall).
BCNJ
