Multiple dash warnings: Stability control not available / emergency brake assist not available / gearbox fault
itsaguything
Manotick, On, Canada
We will have to agree to disagree. The EPB has high electrical power requirements. A battery reading 12.4v is at about 60% capacity.
I'm not saying that something else is amiss. But the first pinpoint test has not passed.
For sh*** and giggles, disconnect the battery. Charge it fully. Let rest for ~6 hours. Perform a reading. If it reads 12.5 or better, reconnect and try it one last time.
Then confirm the connections on the harness....
Mozambique
toronto
Ah okay, I stand corrected. On my third battery in 8yrs of ownership, so strange that this issue has not occurred previously, but hey ** i.e. time before last it kept draining flat and had to boost before I replaced it. But worth confirming as you say
Mozambique
toronto
Huh, looks like the LR Gods took pity on me. Had a look at the ABS module and pressed on all the plugs to make sure none were loose (all seemed okay).
Voila! All dash warning lights gone (they were resetting after engine off and then coming on again after 10 mins driving).
Fingers crossed........
Mozambique
toronto
Spoke too soon
Same codes back with a vengeance.
Will try recharging the battery out of the vehicle as suggested. ABS connections at the module seem okay. Is there a way to definitively check if its an ABSmodule issue?
powershift
Nevada
If your alternator is not the Land Rover brand and it was bought from the parts store then that could be your problem. I hear there is 1 alternative to Land Rover brand, but don't recall what it is. The problem is the compatible alternators are expensive so people buy cheaper alternators then run into issues like what you are having.
jlglr4
Northern California
if that brake switch code is returning, I’d probably replace that first before doing anything else. Even if it’s working to turn the brake lights on, any jitter in that switch might be compromising the signal to the other modules.
WandWover
