New, with a question
JPsLR
Hello, I purchased a 2006 LR3 at the end of Feb, and I am learning things everyday. I am having trouble with my windshield washer. When I push the button, I see my headlamps being washed, but no fluid comes out onto the windshield. Please help. Thanks JP
welcome to the forum. I would check the fluid level and a possible issue with the one way check valve.
pvangura
A second thing to check, as this happened to mine once, would be the hoses that connect to the washers. Somehow I managed to pop them off, and the washer fluid was just spraying out of the hose into my hood liner, and not onto my windshield.
-Paul
Good info Paul.. sadly that just isn't good. If this is the case, may I suggest some small zip tie's.
pvangura
Yeah, it was a strange one. Mine was also an 06, and I have not had the problem with my 07. The hoses are just popped onto a connector end, without anything but the barb of the connector holding them on. I think I used a small zip tie (or maybe a little duct tape??) to fasten it a little better.
PE_in_UAE
