Newbie misc questions
K
kend1606
Picked up my "new" '04 SE7 (17k miles) about 4 weeks ago and am very happy with it. Last weekend was the first time I have taken it truely off road. It performed very well over some demanding roads and "trails". It also came home very muddy! I went through my usual car wash and everything came clean except some areas that might need more serious cleaning. Question: what is the recommended cleaning procedures or warnings for this year/model? For instance, can I take my home pressure washer (max 1200psi) and use a reduced setting (maybe half or less pressure) and spray the wheel wells out? Anythings to watch for? I understand from my indy mechanic that he has seen problems with an electrical connector that is in the left rear wheel well above the tire. I think he said it was a connector in the wire that feeds the fuel pump?? I also would like to spray the areas around the rear mud flaps as there is a lot of mud stuck where the flaps meet the body. This should be OK I guess. Maybe there will not be so much here after my running boards come in. Next ??: My Disco has Goodyear HP 255/55/18's and I would be interested in tire pressures that someone recommends. I have tried the manual's recommendation and that was great for off-road. Seems a little firm for highway driving but letting them down a few pounds didn't make the ride smoother so I put them back to the manual's recommended pressures. Maybe raising them a little from here would mean a slight increase in fuel mileage but I would not want to make the ride any stifer since I have had several rounds of back surgery. I'm sure I will need seperate pressure settings for highway travel and one for off-road. I can say that this baby climbs like a goat! I safely went places that I doubt the National Guard could get to! On the TVA map they were marked as "unimproved trails"! What a great ride! Thanks, Ken
Jaak
Ken ... 03 SE-7 here ... use a pressure washer with no problems. Both a shop machine as well as my 1400 psi home machine. I have had no problems with using a washer under the truck. I just don't spay it under the hood ... just use a standard hose there. get all the mud out and spray the undercarriage with a good rustproofing liquid. Friend who ownes an Indi Porsche garage sprayed mine with the Porshe liquid just before winter. Works great!!
K
kend1606
Thanks for the reply. I'll try the pressure washer this weekend to get the mud out of the wheel wells. I'm curious, is the waterproofing that you mentioned a treatment like some factory coatings or just a temporary spray to use regularly? I haven't looked under her carefully but does Land Rover "undercoat" the '04 Discovery's?? Thanks, Ken
Jaak
Very little undercoating. The Porsche product is like an oil film that sticks to all parts. You can also use WD-40 every few months or so.
K
kend1606
Thanks, but curious about undercoating
Why would such a vehicle not come from the factory thoroughly undercoated? Again, any places that should not be sprayed with WD-40 or equivalent before going into water and muddy places? By the way, hand pressure washing did a great job even after I had to let the mud dry for a couple of days. Thanks, Ken
Jaak
Don't spray the brakes ...... WD-40 works great on electrical connections.
Undercoating may not be an important issue with LR .... or .... an additional "sales point" at the stealer ....
BCNJ
