No spark
norm
Hi all... how do i check the amplifier. As i have no spak at all. thank's
No Spark, sounds like the crank sensor. Do a search on here and you will find detailed instructions on its location.
norm
Still no spark
HI all Just found out that the distributor was removed by the man fiting a new gas Convertor why i dont no??.. All volt checks a coil are ok. Ohms at pick up coil are at 3.7 when cranking there is a voltage. Can the diszy be 180 out number 1 seems to line up, if one tooth out will that stop the spark.... thanks
ps 1995 Disco
1 tooth out will not cause no spark... Could be the alarm... try locking and unlocking the door 3 or 4 times... with key
norm
got it right
YOU MUST USE LAND ROVER rotar button AND CAP. COST ABOUT $ 100 OR SO. IT MAKES IT RUN FINE..:hello:
Sorry to hear you had to learn this the hard way...
